Old 02-05-2014, 09:42 AM   #1
Everett Hill
Liked 4 Times in 3 Posts
Default Re: Help Picking a Carb: SBF in SS or GT
accepted carb.
ssr-585-vs quick fuel
holley list 1850
holley list 2818
+ the stock holley
The 1850 picked my 289 up 1 1/2 mph.the
et was almost the same, in back 2 back test. Can not run on the 289 in class races with holley have to run 108 on mustang &112 on comet
Everett Hill 2134 STK, SS
Everett Hill is offline   Reply With Quote
Old 02-05-2014, 02:35 PM   #2
FireSale
FireSale's Avatar
Liked 237 Times in 126 Posts
Originally Posted by Everett Hill View Post
accepted carb.
holley list 1850
holley list 2818
+ the stock holley
Thanks. If I run it as a GT car, I can use the carb for a 68 Cougar 302 which NHRA lists as C8OF-D. Everything else I can find out about it says it's the carb for a 390. The specs are 600 cfm, 1536x1536/1250x1313. Under the Holley Dash rule, I should be able to run the carb in this link:
http://www.holley.com/0-80540-1.asp
Specs are 600cfm, 1536/1229 Slightly smaller, but the rule says cannot exceed.
Dale
Dale Shearon
68 Mustang 6394
Old 02-05-2014, 04:44 PM   #3
Everett Hill
You don,t have to run the C80F-D on the cougar 302 in gt the 3 i listed are approved & there are some others, if you run in regular super stock you will have to run the autolite on a 68 mustang.
Old 02-05-2014, 04:57 PM   #4
FireSale
FireSale's Avatar
Thanks again. The 1850 is probably a more sensible choice for my first try at the track. The price is right and there are ways to tune it for better performance on the track.
Dale
Dale Shearon
68 Mustang 6394
Old 02-05-2014, 07:26 PM   #5
jmarkaudio
If you have to buy new get the QF carb. A friend has a B/S Camaro, the QF 780 was worth a little over the Holley 780.
jmarkaudio is offline   Reply With Quote
Old 02-05-2014, 07:43 PM   #6
FireSale
FireSale's Avatar
I need a 600 cdm carb and I don't think QF makes one I can use.
Thanks
Dale
Dale Shearon
68 Mustang 6394
Last edited by FireSale; 02-05-2014 at 07:44 PM. Reason: Can't spell my frick'n name!
Old 02-06-2014, 07:33 AM   #7
Dwight Southerland
Dwight Southerland's Avatar
Liked 784 Times in 196 Posts
Look at QF SSR-585_VS that was mentioned earlier in the thread by Mr. Hill. The accepted products list shows it as a replacement for a Holley 3367, which has the same dimensions.
