Old 09-24-2007, 03:03 PM   #1
SSDiv6
Default Re: Trailer Floor.....Mill Finish Aluminum Cleaning
Be caraeful with the use of abrasives on aluminum unless your plan to apply a primer or epoxy paint. The abrasive will remove the annealing and then you will have a corrosion issue with the aluminum. Use the RV-455 and you will be safer.
Old 09-25-2007, 10:24 PM   #2
Lynnmsp
Dave will you be at Columbus?Used RV455 today and was very surpised.It has simple green beat ten times over.I will need more product.I have an other person coming tomorrow to get a sample for a test on his trailer.I am sure he will want a gallon also.
Lynnmsp is offline   Reply With Quote
Old 09-25-2007, 11:34 PM   #3
RIBEIRO RACING
Guest
Posts: n/a
Wink Re: Trailer Floor.....Mill Finish Aluminum Cleaning
Lynn,
No, I will at Budds Creek, Md (MIR) IHRA Nats this week..Good Luck at Columbus...Also,glad you like the product and remember it is the Dam Best Blackstreak Remover out there...Send me an e-mail and I will take care of your needs.... thanks, Dave...1033/stock (350 ci)
