Old 02-09-2014, 05:06 PM   #13
Rob Petrie E395
Liked 216 Times in 77 Posts
Default Re: transfer tanks/towing
I have a transfer tank in a Gas truck. I put a electric pump out of a Tbi pickup in mine and ran the line to the top of the tank. Through a fitting that I welded into the tank.. And then down to the filler neck with a fitting welded on there as well. If you keep a couple of gallons in the tranfer tank and don't run it dry. It will still hold enough pressure to keep from kicking a CEL for evap. emmissions. Nice part is I can run down the road and flip a switch to fill it up and not have to stop to transfer fuel.
