In comp or in class for stock and superstock. For all races It is the towers responsibility to get the index right. Not the racers. (been there done that). There is no shoe polish, no dial in. It is not the racers job to even make sure their own index is right.
Art Leong 2095 SS Last edited by art leong; 02-10-2014 at 06:02 PM. |
Liked 333 Times in 180 Posts
Art--- However IN COMP if the tower has posted an INCORRECT index on the tree and you stage YOU ACCEPT that index as the correct index!!!!
If you do not stage there is still time to correct the index. |
Liked 9 Times in 3 Posts
why such a low index hit .510 under? the bottom of the sheet is usually faster than that. I would think a .7 .8 would be closer, or even a second under but .51? take Pomona for example you have to go all the way back to I think #46 qualifier for .51 under. everyone will be on the brakes at the 1/8.
Mark Markow 171 ss/tb Last edited by Mark Markow; 02-10-2014 at 07:33 PM. |
Liked 135 Times in 74 Posts
Tower getting indexes wrong happened in Comp at the dutch classic in 2011
In CIC racing it is 1st to finish line and you better take as little stripe as possible. Go to inside comp and see how they are beating up a racer for taking permanent hit for taking the stripe by 14ft. Probably going to hang out at finish line to watch the smoke coming off the tires for these races, In a race like the open, the object is save as much as possible until the final. Maybe semis to get to the money round is not a bad idea either. Also watch what other races have taken, so if all semifinalists have run 1.20 under index and you are clean, (not faster than .510 under original index) you get to go at it make sure you take the stripe. Know your competition |
CIC only applies to Comp Eliminator. CIC starts at -.510 under, and goes .01 reduction for each hundredth past -.510 you go. -.570 = .07 reduction; -.730 = .23 reduction. -1.000 is a .50 reduction. No permanent index reductions at Opens, so on Monday, all Indexes go back as they were.
Mike Carr, Tri-State S/SS Association President Looking for 2015 S/SS Race Sponsors Contact me if interested buffdaddy_1302@hotmail.com (724) 510-5912 |
#6 | |
Mark Markow 171 ss/tb |
#7 | |
You are responsible for checking the dial ins. The tower is responsible for checking the indexes
Art Leong 2095 SS |
Liked 13 Times in 10 Posts
I could be wrong but i thought the cic and combo races were in addition to the regular eliminators for stk and ss???
#9 | |
Liked 502 Times in 130 Posts
Not sure if racers like one class combo or not. I liked it the old way but something new can be fun too! Eric
Eric Merryfield 1883 STK Last edited by Eric Merryfield; 02-11-2014 at 03:49 PM. Reason: Just epping is a one day on the daily schedule. |
