Old 04-30-2015, 01:36 PM   #1
carl hinkson
Liked 18 Times in 10 Posts
Default Re: cast iron bowtie
Originally Posted by firebird View Post
i have been searching for a new set of phase 2 bowtie (14011034castings) heads--i haven't had any luck ---are they discontinued ?
Probably are discontinued since GM is offering the Vortec Bowtie heads which are light years over the older Bowtie heads.
carl hinkson is offline   Reply With Quote
Old 04-30-2015, 09:03 PM   #2
race watcher
I have 1 head new. It is out of box but has never been touched. I would like to give it a new home.
race watcher is offline   Reply With Quote
Old 05-01-2015, 01:07 AM   #3
MAURICE BLENDHEIM
Liked 284 Times in 87 Posts
Firebird…Try Reher-Morrison's. They might have some "upstairs". Good Luck…MB.
MAURICE BLENDHEIM is offline   Reply With Quote
Old 05-07-2015, 10:09 AM   #4
firebird
What pistons can i run with the vortex heads----i have Mahle dome pistons with my rotating assembly. Is it wise to machine them to fit?
firebird is offline   Reply With Quote
Old 05-07-2015, 10:59 AM   #5
Dragsinger
Liked 99 Times in 60 Posts
Firebird, an experienced machinist will have a fixture to measure the piston dome/top thickness. If you can machine to the needed dimension and have enough thickness remaining it will be fine to do so.
I "think" it has been said the Vortec is best with very small or no dome.
I do not know the min thickness needed but figger someone will help with that.
Larry Woodfin 471W
Old 05-07-2015, 03:43 PM   #6
firebird
thanks for the reply ---maybe i'm to old to take a shot at this class---would a different set of pistons be a better option ? i want good compression ratio--THANKS FOR THE HELP
Old 05-07-2015, 06:26 PM   #7
Dragsinger
Firebird, what are your plans? What class and buildup details?
Larry Woodfin 471W
