Old 05-07-2015, 10:09 AM   #1
firebird
Default Re: cast iron bowtie
What pistons can i run with the vortex heads----i have Mahle dome pistons with my rotating assembly. Is it wise to machine them to fit?
firebird is offline   Reply With Quote
Old 05-07-2015, 10:59 AM   #2
Dragsinger
Liked 99 Times in 60 Posts
Firebird, an experienced machinist will have a fixture to measure the piston dome/top thickness. If you can machine to the needed dimension and have enough thickness remaining it will be fine to do so.
I "think" it has been said the Vortec is best with very small or no dome.
I do not know the min thickness needed but figger someone will help with that.
Larry Woodfin 471W
Old 05-07-2015, 03:43 PM   #3
firebird
thanks for the reply ---maybe i'm to old to take a shot at this class---would a different set of pistons be a better option ? i want good compression ratio--THANKS FOR THE HELP
Old 05-07-2015, 06:26 PM   #4
Dragsinger
Firebird, what are your plans? What class and buildup details?
Larry Woodfin 471W
Old 05-07-2015, 11:57 PM   #5
firebird
I'm still banging away at the ss/cs with a 350 chevy
Old 05-08-2015, 12:59 AM   #6
SSDiv6
You can use the large port Bowtie Vortec cylinder head or the approved Dart Cast Iron head.
Old 05-08-2015, 05:40 AM   #7
Dragsinger
Firebird, in that situation I expect you will want a piston specific to the head you decide to run.
Larry Woodfin 471W
Old 05-08-2015, 11:13 AM   #8
SSDiv6
You should contact Randy or Michael Mans.
They held the record many times in the class with the Bowtie Vortec heads.
They also flogged and tested every cylinder head in the market and stayed with the Bowtie Vortec.
Do a search were Michael speaks about his experiences with the different heads for SS/CS.
Old 05-08-2015, 12:32 PM   #9
Glenn Briglio
Glenn Briglio's Avatar
Liked 974 Times in 310 Posts
Angry Re: cast iron bowtie
DO NOT USE vortec bowtie heads!!!!!!!!!! Ask me how many sets I have seen cracked for my SS/CS customer.
