#1 | |
Liked 216 Times in 88 Posts
This could be a good thing but realize that Live Timing is not going to be available at all D1 events because it is tied into the Compulink system just as our system was tied in. Lebanon Valley runs on Portatree, so Live Timing will not work there. It will also not work at Compulink tracks that do not have a working data feed to tap into. Virginia never worked properly, so I always had to enter everything manually, as I had to do at Lebanon Valley. The rest of the D1 tracks have the correct hookup, though each had a problem at one time or another that prevented me from getting the datafeed. DRC is going to continue to post results remotely at the end of the day. I am going to continue to put summaries and recaps on my website to build an archive. Jim
Jim Samuel |
Liked 544 Times in 213 Posts
Live timing should be modified so it does not show some info that an opponent can look at and gauge how to race someone else
Do not show RT's and incremental times.... Racing should be a bit of a guessing game....or Chess match if you prefer that term... The added info helps some and hurts others... Just an observation and opnion from someone who has been in the sport nearly 50 years......
The Portatree system at Lebanon Valley DOES support NHRA/Compulink style live timing (as do all of our Professional Systems). It also supports another style of live timing that is used in the Middle East. We are also open to making changes to help.
#4 | |
Jim Samuel |
Liked 13 Times in 9 Posts
NHRA Div. 3 also has live video this year, see "D3TV" on www.nhradiv3.com.
All IHRA events are broadcast live on www.motormaniatv.com, with end-of-day qualifying/results posted on their sister site, www.dragstory.com.
#6 | |
Liked 228 Times in 70 Posts
Liked 288 Times in 90 Posts
OK Pup.......go ahead and talk slow so I can write them down.....
RJ |
Liked 10,711 Times in 2,230 Posts
^^^^^^^ What he said!
#9 | |
I believe the system is set up so that it does not show RTs and incrementals until; after the run has been completed.
Jim Samuel |
