Old 11-11-2007, 02:04 AM   #1
Mitch Perkins
Mitch Perkins's Avatar
Default Re: Inner tube nut
I think they are 3/8-24 . But don't hold me too that #
Mitch Perkins Perk-Bilt Race Cars
DragCoverage.com Staff Photographer
Mitch Perkins is offline   Reply With Quote
Old 11-11-2007, 01:20 PM   #2
FED 387
Liked 335 Times in 182 Posts
I believe the correct nut thread size is either a 12 or 16 MM fine thread-Depends on the valve stem size---By the way these valves are known as PRESTA valves the other type is a SCHRADER which is the type most generally used in TUBELESS automotive applications------Right tho on the wheel spinning on the tire can cause mucho problems---Comp 387
Old 11-11-2007, 02:27 PM   #3
Dave Goob Cook
Dave Goob Cook's Avatar
Apply Palmolive dish soap to the sidewalls inside, and ditch the tubes.
Dave Goob Cook is offline   Reply With Quote
Old 11-11-2007, 09:25 PM   #4
Philip Saran
Liked 14 Times in 11 Posts
Guys, thank you for the input. At this point the tubes will stay, later in 2008 I'll be switching
to MT radials and will leave the tubes out at that point.
Phil Saran
Parker, Colorado
Philip Saran is offline   Reply With Quote
