Old 07-11-2015, 04:56 PM   #1
Signman
Liked 269 Times in 99 Posts
Default Re: New to Stock - Buying an 85 Camaro G/H/I??
Originally Posted by Greg Hill View Post
There is no way those parts cost 15,000 for a small block Chevy. The block is around $1300, the rods about $600, pistons and rings $1200, roller rockers $300, don't know about tool steel lifters, we run Smith lifters which are around $700. That adds up to $3700 before the heads and intake. Let's allow $4300 for the heads and intake from Top Notch. Looks like 8k to me. I realize it takes more parts than that, cam, bearings, gaskets, oil pump, and assorted others. I bet you I could get an good engine builder I happen to know well to build a 1.10 under 305 for 12k with some really good stuff and would go right through tear down.
The next tenth is 10K at least if you already have the rest of the car sorted out.
Old 07-11-2015, 05:47 PM   #2
Allen Sherman
Banned
Liked 5 Times in 3 Posts
Not gonna get in a pissing match on here but here's the break down on parts cost:
Dart block all done, bored, honed, lifter bushed and race ready is $2500
Top notch heads and intake with valves, springs, head studs and guide plates $5000
Tool steel lifters top notch dlc coated from trend $1100
Roller rockers from comp, ultra pro magnum $500+
Metric ring set with ring spacers (best stuff) $1375
Manley pro I beam rods $1175
Cp stocker pistons $800-1000
Good crank is gonna run you $1000
And you still haven't bought pushrods, gaskets, timing set, bearings, timing cover, oil pan, carb, and all the little accesories. I build these for a living and buy the parts on a daily basis so I kinda know what it costs...and I also can gurantee mine will go "right through tear down" also...
Allen Sherman is offline   Reply With Quote
Old 07-11-2015, 08:40 PM   #3
HR9121
HR9121's Avatar
Wow! My little spare parts 6k motor is looking better all the time lol. Don't run too bad either.
James Williamson
W200 J/SA. SS/JA
Old 07-11-2015, 09:11 PM   #4
Bill Diehl
Bill Diehl's Avatar
Liked 9 Times in 8 Posts
roller rockers from comp
Double that if you opt for the big studs, and install adjusters in the rockers...triple it if you can't do it yourself.....and I am jus talking about the rockers
Bill Diehl is offline   Reply With Quote
Old 07-11-2015, 10:42 PM   #5
Dave Gantz
Liked 251 Times in 125 Posts
Wow. Definitely not the Stock Eliminator I was attracted to in the 70's!
Old 07-11-2015, 10:56 PM   #6
Chris1529
Liked 70 Times in 29 Posts
Although its a completely different sport, I'd like to share a line from Robert Duvall from the movie "Day's of Thunder". "There's nothing stock about a stock car"
Chris Bowman
The Mountain State Mustang
1984 Mustang GT350
Old 07-12-2015, 07:57 AM   #7
Signman
"Stock is not Stock" Gerry Stein
Old 07-12-2015, 11:29 AM   #8
Allen Sherman
Banned
Chris and frank those are both funny and true statements...lol...I've been racing stock over 20 years now and my dad raced since the 60's and we constantly have a conversation about how drastic the rules have changed even just in the last 6 years, much less how different it was when you had to have the stock valve spring height and pressures, stock cam durations and overlap and such...evolution is reality as far as this all goes...
Old 07-12-2015, 01:59 PM   #9
FINESPLINE
FINESPLINE's Avatar
Could not have put it any better !
FINESPLINE is offline   Reply With Quote
Old 07-12-2015, 12:00 PM   #10
davidhuff
Liked 120 Times in 42 Posts
Why do heads and intake cost $5,000?
Thanks,David
