Old 08-18-2015, 12:28 AM   #1
boxmotorsports
Liked 58 Times in 23 Posts
Default Q jet base gaskets
we have a J/SA ,255hp 69 Chevelle wagon, Does anyone have the part number of the 1/4 inch base gaskets for a Quadura jet ? Thanks
boxmotorsports is offline   Reply With Quote
Old 08-18-2015, 02:27 AM   #2
Greenlight
Liked 79 Times in 22 Posts
Default Re: Q jet base gaskets
Fel Pro 17845 is one option.
Greenlight is offline   Reply With Quote
Old 08-18-2015, 07:56 AM   #3
Brian Fink
Liked 28 Times in 9 Posts
Jegs/Summit has most of the Fel Pro numbers ; I use #1908 .
Brian Fink is offline   Reply With Quote
Old 08-18-2015, 09:22 AM   #4
henrys57wagon
henrys57wagon's Avatar
Also look up Chryco Q'jet base gaskets.
old 1608 stock racer
henrys57wagon is offline   Reply With Quote
Old 08-18-2015, 09:43 AM   #5
Jim Parsons
Liked 195 Times in 30 Posts
I have always been under the impression that rule book called out "maximum two 1/4" carb base gaskets"? I was told by reputable long time stock racer that its just two gaskets with no specific thickness! Not sure it make any big difference but dose anyone have clarity?
Jim
Jim Parsons is offline   Reply With Quote
Old 08-18-2015, 11:28 AM   #6
bbaker1207
i use a couple fel pro 60335 gaskets
bbaker1207 is offline   Reply With Quote
Old 08-18-2015, 12:04 PM   #7
Billy Nees
Liked 7,718 Times in 1,738 Posts
Jim
From 2015 Rulebook, "Carburetor heat-insulator-type gaskets prohibited. Maximum of two stock-type gaskets permitted".
Billy Nees 1188 STK, SS
Old 08-18-2015, 12:40 PM   #8
Jeff Niceswanger
Liked 1,031 Times in 368 Posts
Bought theses off Mike Keown many years ago. They are 1/4 inch thick
Name:	Carb Base Gasket 028 (640x427).jpg
ID:	30140   Click image for larger version
Name:	Carb Base Gasket 027 (640x427).jpg
Jeff Niceswanger 3740 SS
Jeff Niceswanger is online now   Reply With Quote
Old 08-18-2015, 03:05 PM   #9
boxmotorsports
Jeff, I think that open style gasket is OK for a open plenum intake manifold,, but on a stocker cast manifold, it should be a 4 hole , shouldn't ?
Old 08-18-2015, 03:13 PM   #10
njk53
For what its worth, several years ago we tested with the open gasket vs. the 4 hole gasket on the dyno and the 4 hole gasket made slightly more power and torque with our combination.
Nelson Kowal
Stock 345
