Old 08-31-2015, 01:12 PM   #11
Billy Nees
Liked 7,925 Times in 1,760 Posts
Default Re: 66 Fairlane Wagon Combination Suggestions
66 390 has a Autolite carb, iron intake, .430 something cam and 11.8 blueprinted compression.
67 390 has a Holley carb, aluminum intake, .480-.490 something cam and 12.8 blueprinted compression.
Both are rated at 319 HP. 67 390 is the way to go.
Billy Nees 1188 STK, SS
Old 08-31-2015, 03:32 PM   #12
FireSale
FireSale's Avatar
Liked 237 Times in 126 Posts
I looked up both the 66 and 67 Fairlane on OldRide.com for specs and they seem about the same. Wheel base and overall length of wagons are the same. Here is a quote from the text of the 67 article:
"For 1967 the Fairlane was the base trim level model. It continued to use the same body as the one introduced to 1966 but with minor trim changes. The new grille was an aluminum single stamping instead of the two grilles used in the previous model and the taillights were divided horizontaly by teh back-up lights, instead of vertically like the 1966 Fairlane. You could get the Fairlane with a 410-hp or a 425-hp (dual Holley four-barrel carburetors) 427 cu. in. V-8."
Looks like with some minor trim changes, that 66 could become a 67 and use that previously mentioned 390 with the Holley 4BBL. I think it's rated at 320 HP.
That Holley is List 3793 for the "A". According to the Quick Fuel catalogue, the SSR 585 VS is a legal replacement for it.
Edit: My 67 Ford NHRA Engine Blueprint file says that 390 is rated at 320 HP with 10.5 compression. The Holley carb is C7OF A,B,C or D
Dale
Dale Shearon
68 Mustang 6394
Old 08-31-2015, 05:09 PM   #13
Dwight Southerland
Dwight Southerland's Avatar
Liked 784 Times in 196 Posts
Billy's right. (cough, cough, gag)
Old 08-31-2015, 05:44 PM   #14
Billy Nees
Dwight, you should get that cough checked out!!
Old 08-31-2015, 06:55 PM   #15
Tom keedle
Tom keedle's Avatar
Liked 8 Times in 7 Posts
had a 66 fairlane GT convert. in high school, had an oem holley on it...
Old 08-31-2015, 07:03 PM   #16
Billy Nees
Ya know, the thing to do here, except for the problem of the NHRA not working this way anymore, would be to get the 66 motor de-factored to about 290 HP. It has more in common with the 63-65 390 which is de-factored to 280 HP from 300 than it does with the 67 390 at 319.
Dwight, a couple of months ago, we talked about asking NHRA to go over the non-competitive 60s and 70s combos and giving them some help. I think that this combo should qualify for that help.
Old 08-31-2015, 07:03 PM   #17
Richard Grant
Richard Grant's Avatar
Liked 13 Times in 7 Posts
The Hall's (I believe) ran a Wagon in G/SA several years ago. Apparently the combo was not competitive even though RJ's Sedan was one bad stocker. Maybe one of the Hall's or RJ could comment on why it wasn't a good choice.
Richard Grant 4988 STK
Richard Grant is offline   Reply With Quote
Old 08-31-2015, 07:54 PM   #18
mtkawboy
Liked 54 Times in 18 Posts
Wheelbase is shorter then a coupe, they are built on a Falcon chassis with Fairlane sheet metal. We ran one in E/S in the very early 70s in Div 2 with a 427/410 until I put it on the roof on 7 inch tires.
mtkawboy is online now   Reply With Quote
Old 08-31-2015, 08:00 PM   #19
Bob Don
Bob Don's Avatar
Liked 905 Times in 193 Posts
Just out of curiousity, is the "fresh air hood" (factory scoop) NHRA legal on the 66-67 Fairlane wagon?
Bob Don 128 SS
Old 08-31-2015, 08:04 PM   #20
Billy Nees
Yes, with the 427.
