Old 10-12-2015, 03:15 PM   #1
Bruce Noland
Liked 444 Times in 145 Posts
Default Pan Evacuation System
Must admit I have no idea if evacuation systems really help. I'm working on a flathead Land Speed motor and wonder if it would help the little guy out. Any pros and cons would be appreciated. Thanks.
Bruce Noland 1788 STK
Old 10-12-2015, 05:03 PM   #2
Tom Goldman
Tom Goldman's Avatar
Liked 888 Times in 239 Posts
Default Re: Pan Evacuation System
Is a vacuum pump allowed or just a closed system using engine vacuum and a check valve ?
Vacuum pumps are well documented to increase Hp even without low tension rings .
I know of a few Stockers with ring packages that slow drastically without the PCV pulling a vacuum in the pan .
Old 10-12-2015, 10:47 PM   #3
Bruce Noland
Thanks Tom. Good point. I was told by SCTA tech that pan evacuation was legal. I can contact them to be sure that we are talking about the same thing, ie, pumps.
Old 10-14-2015, 01:48 PM   #4
dmir55
Just be careful that the engine is sealed. Things like main seals, dipstick tube etc. Nice thing is they tend to leak a lot less. Us pcv system for low rpm and header evacuation system for high speed.
dmir55 is offline   Reply With Quote
