Liked 165 Times in 59 Posts
like mentioned tig is the most controlled of welding and with some practice great results can be achieved
if you a planning a roll bar install and chrome is your choice of material,tig is a must but practice is a must bench welding is one thing ,getting to all of the seams of your roll bar that it is in your car "not easy" alot of planning a head will make this easy a mild steel bar can be mig welded inplace and also can produce great results with practice if purchasing a welder and the tig is of choice,make sure you get a machine that has a water cooled nozzle ,this way when you tackle some aluminun projects the tungsten will not over heat and melt in to your welding project with any kind of welding preping your work is key for the best results gmonde |
Liked 70 Times in 22 Posts
For body panels I have been using tig with Silicon Bronze. Its seems to be more of a braze than actual weld but it works. Works great for filling all the small holes from Clecos, firewall attachments and others up to 3/8" without any metal plug. I just put a quarter on a 68 Cuda and I used mig, not tig, silicon bronze and it went ok. A little more practice and my feeling is it will be the best way for sheet metal.
tig is the better deal if you can handle it. on body panels the welds are much easier to grind.
