Old 12-15-2015, 03:03 PM   #1
Ed Wright
Ed Wright's Avatar
Default Re: Racing seats
I have the poly seats in my car. I have them through bolted and did not use the threaded inserts for mounting. They are not as pretty as the aluminum but are very comfortable and light.
That is what I still have in mine. Through bolted as well. Much more comfortable to me, and light.
Ed Wright 4156 SS/JA
Old 12-15-2015, 07:03 PM   #2
rallye bob
rallye bob's Avatar
Liked 6 Times in 4 Posts
I run the JAZ poly seats in my car, and have them through bolted. The back of the seats are bolted to a brace fabed off my cage. The seats are very comfortable, and rock solid.
Old 12-16-2015, 11:52 AM   #3
rickseeman
rickseeman's Avatar
Liked 2 Times in 2 Posts
I doubt you want to spend this much but they say if you wreck, these are good
http://racetech-usa.com/shop/seats
rickseeman is offline   Reply With Quote
Old 12-16-2015, 03:03 PM   #4
sst7250
sst7250's Avatar
Liked 45 Times in 32 Posts
If you are tall stay away from any of the poly seats. The aluminum ones give you more head room by a few inches.
sst7250 is offline   Reply With Quote
Old 12-18-2015, 10:39 PM   #5
chasracer
We have used the poly and the aluminum in our race cars over the years. The inserts in the poly seats are worthless and as some have noted here, bolting them through is the way to go plus making sure you have the back of the seat supported/bolted to the roll cage cross brace. With the seat installed this way, it does a good job and I think is very comfortable. My boys like the Kirkey seats in their racecars and at least with the optional covers they aren't too bad - w/o the cover the things are rough on the bottom of your spine in my opinion. I also have found that the forward bolster part of the Kirkey seat kind of catches my outer thigh area and tends to hurt eventually. If you have the chance I would see if someone will let you sit in their car to see how they feel to you.
chasracer is offline   Reply With Quote
Old 12-20-2015, 11:41 AM   #6
Eman
Liked 133 Times in 76 Posts
On a stock floorpan car how are you mounting the seats? On thru bolting the plastic seats are you using carriage style smooth head bolts? Are you drillng thru where the inserts are?
Old 12-20-2015, 12:12 PM   #7
Mike Pearson
Mike Pearson's Avatar
Liked 1,943 Times in 584 Posts
I welded some threaded inserts into the floor pan similar to the stock seat mounts. I drilled the threads out of the seat inserts an used a 3/8 grade 8 bolt with a large flat washer to bolt through the bottom of the seat to the floor. 1 half inch bolt through the back into the cross bar
Mike Pearson 2485 SS
