Old 11-30-2007, 02:02 PM   #11
SSDiv6
Default Re: Mopar 440 racers - time to legalize that shortblock!
Originally Posted by Lynn A McCarty View Post
Sounds like "Cross Breeding" to me! Specifically stated in the rule book for Super Stock and Stock.
Lynn
Illegal for Stock, but in SS you can run any intake as long the carb is located in the OEM position. You also adapt any intakes with spacers. The Smith brothers (Pro Trans), ran a Chevy intake, with adapters, in the SS 383/Cuda for many years.
Old 11-30-2007, 03:53 PM   #12
RocketBlock
In Stock class, as long as you run the same OEM material and stroke as the engine you claim, using a crank in the same family is acceptable. As an example, using a cast crank within the different years of a Chevy small block, as long the stroke is identical, it is okay. However, using a forged crank in an engine that had a cast crank is not acceptable.
Incorrect. 440 crank is in the RB family, 413-426W-440 engine size, 2.750" journal size as. RB family as defined by Chrysler.
400 block is in the B family. 361-383-400 engine size as allowable in NHRA competition (other variants predate NHRA allowance for competition). B family as defined by Chrysler.
You can swap a cast crank for a forged crank application as long as the part is OEM and part of the same family. Example. You can use a 396 cast crank from a 265 horsepower Impala in your 375 horsepower Camaro engine for a weight savings. You could also use the standard small bolt rods. These are direct fit, same family applications. Truck crank, boat crank, it would not matter.
Again, "no crossbreeding of parts allowed". Also, "lightening of crankshaft other than normal balance job prohibited" Note: Per NHRA in SS you can turn down main and rod journals as much as you like.
Yes, any intake you can come up with allowable in SS as long as same configuration.
RocketBlock is offline   Reply With Quote
Old 11-30-2007, 04:18 PM   #13
SSDiv6
Yes, that is exactly why I meant; I consider the RB a different family from the B engine.
Old 11-30-2007, 04:48 PM   #14
herbjr
Liked 83 Times in 32 Posts
Rocket post with your real name and I'll continue this discussion.
Herb McCandless Jr
herbjr is offline   Reply With Quote
Old 11-30-2007, 05:01 PM   #15
Jeff Teuton
Liked 325 Times in 50 Posts
I think the 400 is ok in ss, but not stk. I have been wrong before so don't swear on it.
Jeff Teuton 4022 STK
Old 11-30-2007, 06:20 PM   #16
Lynn A McCarty
Lynn A McCarty's Avatar
We arent talking about the intake, we are talking about the reason why you need the 383 intake. Arent they using a 400 block instead of a 440 block taking about 0.800 inches off the piston height? Isnt that the definition of cross breeding?
Pontiac made a 9.200 deck block that with a 400 we could do a very small crank and a very small piston skirt. We were told that is illegal. Several SBC guys I know say they are going to build a short deck 400 since their rods are like 5.35 inches. Wouldnt that be a killer combo too? Did NHRA allow that?
I dont blame the BBM guys for doing it, it is just that if one group gets it then everyone should. I could only do about 0.200, but a 428 could do about .400, and a 400 could do about 0.750.
Lynn
Lynn A McCarty 3470 SS
Lynn A McCarty is offline   Reply With Quote
Old 11-30-2007, 06:43 PM   #17
RocketBlock
Herb McCandless Jr
But there is nothing to discuss. No grey area. Tech needs to enforce the rules as they are printed. I'm told that is in the works. If not, just as Lynn McCarty said, open it to everybody.
Old 11-30-2007, 10:05 PM   #18
Chris Hill
Liked 244 Times in 26 Posts
Hell, a blind man can tell a 440 block from a 400 block.
Rocket, I assume your talking about stock. If the stock rod length is used and main diameter is same, a 400 block as a 440 is proper reading of the rule book to me for SS.
Chris Hill
Old 11-30-2007, 11:06 PM   #19
RocketBlock
Did you read the specifications provided to you? Did you read the part about engine families? Did you read the rules violations? Go back over those items and then get back with your interpretation. Thank you.
Old 11-30-2007, 11:37 PM   #20
herbjr
Chris we know each other from 20 years ago. Dont give to much info as soon as Rocket tells his real name Ill chime back in. He is in left field. And yes a Ray Charles could tell the difference between the two blocks. Can you Rocket without tools just your eyes.
Herb Jr
