Liked 704 Times in 281 Posts
When I went from a old TCI valve body to a Griner valve body I was .035 faster with Griner. Everything else in car was the same.
I have had three transmissions in mine, I won't name the other names, but whatever the Smiths put in my Pro Trans is faster than the other stuff I had. Only button I can find slow enough, even using a blinder, is the Just-N-Time button.
Best transmission I ever ownned as well.
Ed Wright 4156 SS/JA |
Do you guys mean faster in reaction time or ET?
Liked 101 Times in 52 Posts
Is "faster" by dumping the reverse fluid quicker?
The Pro Trans made the car faster, but I was referring to my lights. Suddenly going red with my old button.
Okay thanks guys!
Liked 689 Times in 198 Posts
When I raced super-gas I made my own trans brake buttons from surplus snap switches available at a local electronic store for about $2.50 a piece.
This is a similar one that can be ordered for about $9.00. I just made my own shims to change the length of the button travel. I could red light easy when used with little travel. |
Liked 883 Times in 237 Posts
Pro Tree brakes are typically fluid exhaust , meaning they rely on line pressure to move the valve when the solenoid releases . .....They are really intended for the Super .90 classes . makes it hard to not go red on a full tree .
They typically us much higher line pressure than a spring actuated valve . Higher line pressure = more HP consumption = slower ET's !
