#11 |
Liked 165 Times in 59 Posts
tom:you went 10.80 on a amc 20 ,man ,the model 20 blew up two times of coarse it was a stick car,the model 20 is an afficaint rear dana 60 is strong but heavy, 8 3/4 should be about the same and i now alot of guys make it work in high horse power situations , gmonde
#12 |
Liked 883 Times in 237 Posts
Unfortunately the 69 factory Hurst AMX has a factor of 7.49# , Just enough to keep it out of AA/S. Unless you can adjust down 1 class with it. .................... Of course you would have to find someone at the New Chrysler Corp. who would push it thru to NHRA, since it was only a 50 unit car! .... I dont know if a car that is an accepted 50 unit combo in Super Stock is automaticaly accepted in Stock. ...... Tom
Tom Goldman 1500 SG , 1506 STK Last edited by Tom Goldman; 12-08-2007 at 01:51 PM. |
#13 |
Liked 780 Times in 194 Posts
I believe that if you really look at the specs on that engine(1969 390/340 AMC) , it will pretty much be a no-go for AA/S anyway (at 407 hp).
#14 |
You must use the 45 degree seat angle.
#15 |
Dwight, I'd think the Crane fully ported heads would be another stumbling block, Altho they are pretty tame compared to what it would be up against. ....Just an outloud daydream. ........Tom
