Old 03-21-2016, 04:48 PM   #1
Ed Wright
Ed Wright's Avatar
Default Re: Oil starvation issues SBC HELP?
Originally Posted by joespanova View Post
Ed , you may want to read this:
about an accumulator
http://rehermorrison.com/tech-talk-5...-engine-alive/
I know about those. Had one on a circle track car for a while, until they made dry sumps legal.
Ed Wright 4156 SS/JA
Old 03-21-2016, 04:52 PM   #2
joespanova
Liked 13 Times in 11 Posts
Are you a SS racer?
In traditional Super Stock cars I would think an accumulator is popular since you cant use dry sumps?
Old 03-21-2016, 06:46 PM   #3
Ed Wright
Ed Wright's Avatar
Are you a SS racer?
Yeah, I have raced Super Stock a couple of times. I don't know of any Super Stock racer using an acumulator, or any Super Stock racer that needs one. Guys going a lot faster than you are. Circle track cars that often run 25 to 30 laps around a circle track without lifting, is another thing. Your the one with oiling problems. You have someone like Carl Hinkson & Mike Taylor trying to help, but don't seem to want to hear what all your doing wrong.
Old 03-21-2016, 07:14 PM   #4
joespanova
Man you are a grumpy old azz aren't ya?
Do you read my replies? If you did you wouldn't say that.......geeezus christ. Am I dealing with men here....or women?
For the second GD time.....I AM listening / reading.
You're also the one that says throw a windage tray away when almost all others say they work?
Old 03-23-2016, 10:12 AM   #5
Jim Hanig
Liked 99 Times in 49 Posts
Joe i run the same pan ,and found out i couldnt run less than 6 1/2 quarts the engine would lose pressure, still have the pan but always run 6-7 quarts with no pressure loss.I run 2.2 and 2.7.
Old 03-23-2016, 10:20 AM   #6
joespanova
http://www.ebay.com/itm/Moroso-21015...dW6ZCr&vxp=mtr
This is the EXACT pan I have.....
Old 03-23-2016, 10:37 AM   #7
Mike Taylor 3601
Mike Taylor 3601's Avatar
Liked 308 Times in 103 Posts
The only time I have had oil pressure issues on SBC that I have assembled is when I had a 3/4 diameter pick up,whether it was windage or the pick up,I don't know?? but i do know I switched to 5/8 pickup and my issue went away ,I don't know if anyone else has had same experience,but I have on two different engines.
Mike Taylor 3601
Old 03-23-2016, 10:41 AM   #8
Mike Pearson
Mike Pearson's Avatar
Liked 1,937 Times in 582 Posts
[QUOTE=joespanova;499144]http://www.ebay.com/itm/Moroso-21015...dW6ZCr&vxp=mtr
This is the EXACT pan I have.....[/QUOT
I ran one of those Moroso pans for many years with no oil related issues. I doubt it is the pan causing problems. What oil and filter are you running? I don't run any passenger car oil or filters any more I also run a billet Moroso oil pump as well. Idles at around 35 and about 80 in the lights. I also have an idiot light to warn me if the pressure drops below 15 lbs.
Mike Pearson 2485 SS
Old 03-23-2016, 02:36 PM   #9
carl hinkson
Liked 18 Times in 10 Posts
The other issue is the aluminum rods are bulky or big and create alot of windage over steel rods.
carl hinkson is offline   Reply With Quote
