Liked 70 Times in 31 Posts
But why is it only performance based for qualifying, setting records, class runoff and if you happen to draw someone in your class? Why isn't every round performance based? Example.... like they run the combo class runoff. Why don't they run the entire race based on performance?
Darrel Goheen 785-623-7021 Stock Eliminator 585 94 Camaro Z/28 LT1/ET 585 67 Chevelle 427 Tehnician for JustAnswer.com Last edited by Darrel Goheen; 05-06-2016 at 09:55 AM. |
Liked 7,866 Times in 1,750 Posts
If you think about it for a second, it is. Where you qualify on the sheet(based on your performance) dictates who you will run throughout the eliminator.
#3 | |
NHRA then went to these bogus slow indexes so the slow guys would come back. So now many of us use restrictor plates, or throttle stops, or throw a couple hundred lbs in the car, or just shut off at 1000' to slow down. Go too fast, get hateful text messages. Gets tiresome.
Ed Wright 4156 SS/JA |
#4 | |
Liked 41 Times in 9 Posts
Joe Franco SS176 |
No joke, Joe. We got 2 rounds worth of points (used to be 100 per round, so 200 for et records, 100 for MPH records) so guys would bump the record, if they could run under it enough, for points. I did it 3 times, held it that time they did away with Stock Eliminator.
If you could not run the record, the car that ran the closest won the round if they didn't screw up. We ended up with very low car counts when bracket racing came along. Guys that had no chance went bracket racing. I still see some of them running super street & super gas. The slow indexes must have been to give the slow guys a chance, right? Why else? Car counts came back up. Many came back. Beginners now have a better chance. If you can't run under these indexes, you need to try golf or fishing.
I constantly hear different people looking for a less popular class or one that no one else is in.....all trying to avoid a heads up race just like I want to do. I understand those that desire to work hard to get the performance but it seems with one or two changes we could all have what we want to a degree. Here's what I'd like to see. Points rounds should all be a bracket race instead of only when you draw someone in in your class.
I have no problem at all with qualifying based on performance.
Darrel Goheen 785-623-7021 Stock Eliminator 585 94 Camaro Z/28 LT1/ET 585 67 Chevelle 427 Tehnician for JustAnswer.com |
#7 | |
Guest
Posts: n/a
Ah NO!!! Go race all the great 10K and up races that Mike Beard talks about all the time. If you want to race stock, there is a chance of heads up in eleminations. If you don't want that, then find another venue. Or build a car that can run classes less populated. Done
Liked 783 Times in 195 Posts
Those who want to tout the "good ole glory days" should remember that the same fears and reality chased Stock racers away from the big races back then - the opportunists in the low classes. The cars people have in mind now that will have the advantage are the low class cars, just like back then. Remember the Y/SA Chevelle 6 cyl wagon of Eugene Chaisson and Bob Shaw's Corvair at the 1976 Sportsnationals to know that things have not changed much.
SO, if we have a true "performance based" eliminator, how many people would do the smart, practical thing and build a 13-sec competitor, or stay with their 10-sec beauty queen and just gripe?
#9 | |
I'd be curious to know if the quicker cars in class if the engines were built by the car owners/drivers vs. buying them from a builder. If the latter is true it's just a money class (more money=more performance). I'd also be curious as to whether stock racers would rather see more stock cars or less at a race. If the latter is true why not change it to run eliminations like they do in the class combo.... Dial everyone at index and whoever gets there first wins. That would make it a true performance class.
#10 | |
Liked 13 Times in 9 Posts
