Old 05-26-2016, 12:29 PM   #1
V M Kauffman
Default Re: Crankcase Pressure
The better the engine is sealed up the less Blowby you will have which equals less Crankcase Pressure you will have. If the engine is a wet sump you can measure the Blowby with a good Blowby meter. Low leak down readings do not equal low Blowby.anything over 2cfm is too much.
V M Kauffman is offline   Reply With Quote
