Liked 13 Times in 11 Posts
Liked 33 Times in 16 Posts
Joe - That would be assuming one would want/allow the oil to drain back directly over the crankshaft.
Rich Taylor I/SA - 321 |
#3 | |
I'll manage windage some other way........ |
I'm no expert for sure, but I also don't have any Dart blocks lying about. It's my understanding that the Dart blocks oil differently and likely less oil up top to contend with. Using these old GM blocks my solution just seems to make sense to me.
What you did makes sense to me ..............on an OEM block , yes.
Liked 7 Times in 5 Posts
Ok i'm assuming a header vac system isn't legal in stock either since no one has mentioned it? and it would seem a obvious answer.
#7 | |
Liked 800 Times in 237 Posts
![]() The valley is much like a big block Chevy. They are a priority main oiling system, so the mains get oil first, then the cam/lifters....just the opposite of a factory small block. You can flood the top end pretty easily, so the lifters need to be chosen carefully.
"That'll never work....." |
#8 | |
#9 | |
Liked 18 Times in 10 Posts
Dart blocks do use priority oiling and they get the same oil up to the top as a stock block. Nothing is restricted on the block to decrease the flow of oil to the top end. Don't use the Dart cam bearings with 3 holes to much bleed off if you want to talk about oil running down on the cam. |
#10 | |
