Old 07-11-2016, 09:42 AM   #1
HandOverFist
HandOverFist's Avatar
Liked 33 Times in 16 Posts
Default Re: Crankcase Pressure
Originally Posted by joespanova View Post
You'd think Maskin and gang would be well aware of that.....myself . I want the oil to get back to the sump as quickly as possible.
I'll manage windage some other way........
I'm no expert for sure, but I also don't have any Dart blocks lying about. It's my understanding that the Dart blocks oil differently and likely less oil up top to contend with. Using these old GM blocks my solution just seems to make sense to me.
Rich Taylor
I/SA - 321
Old 07-11-2016, 10:15 AM   #2
joespanova
Liked 13 Times in 11 Posts
What you did makes sense to me ..............on an OEM block , yes.
Old 07-11-2016, 01:21 PM   #3
pfordamx
Liked 7 Times in 5 Posts
Ok i'm assuming a header vac system isn't legal in stock either since no one has mentioned it? and it would seem a obvious answer.
pfordamx is offline   Reply With Quote
Old 07-11-2016, 08:49 PM   #4
Alan Nyhus
Liked 799 Times in 236 Posts
Rich, here's a Dart SHP:
The valley is much like a big block Chevy. They are a priority main oiling system, so the mains get oil first, then the cam/lifters....just the opposite of a factory small block. You can flood the top end pretty easily, so the lifters need to be chosen carefully.
"That'll never work....."
Old 07-12-2016, 01:05 AM   #5
HandOverFist
That's a nice looking piece there Alan...maybe some day before I die I will get to join the big boy ranks. With holes that large I would at a minimum have to screen them just for peace of mind.
Rich Taylor
I/SA - 321
Old 07-12-2016, 07:35 AM   #6
carl hinkson
Liked 18 Times in 10 Posts
Dart blocks do use priority oiling and they get the same oil up to the top as a stock block. Nothing is restricted on the block to decrease the flow of oil to the top end.
Don't use the Dart cam bearings with 3 holes to much bleed off if you want to talk about oil running down on the cam.
carl hinkson is offline   Reply With Quote
Old 07-12-2016, 08:33 AM   #7
joespanova
......and IIRC that's easy to see when priming on the stand with the intake off........I'll vouch for that.
Old 07-17-2016, 03:34 PM   #8
Bobby Fazio
Bobby Fazio's Avatar
I was getting oil in the intake. I'm going to try an oil separator and reconnect the pcv valve to the factory spot in the back of the manifold. So let me see if I understand this. At idle the gases are being sucked into the valve cover breather through the crankcase, out the pcv valve and back into the manifold. At full throttle the pcv check valve is closed and the valve cover breather is handling all evacuation of the crankcase?
'65 Mustang SS/L & L/SA
