Old 07-20-2016, 03:03 PM   #1
Todd Gross
Liked 54 Times in 24 Posts
Default Re: 302 SBF Dart block potential cooling system issue
Originally Posted by Maverick View Post
Curious, does the block and heads have steam holes, do you run a alternator? Just don't trust electric instruments, when strange things are going on.
Yes the Dart Block has steam holes in the same location as the OEM block. I used Cometic head gaskets where the previous were Fel Pro. Both Head Gaskets have the steam holes and passages in the same, and I would say, proper locations.
The sensor was in the left front corner of the intake manifold. For a test we moved it to the left rear corner of the intake. It does not have a coolant cross over in the rear, but was in the coolant passage. No difference in the data log.
Yes on the alternator.
Todd Gross is offline   Reply With Quote
Old 07-21-2016, 01:43 PM   #2
Mike Taylor 3601
Mike Taylor 3601's Avatar
Liked 319 Times in 108 Posts
Don't want to insult anyone with a question like this,but haven't seen it mentioned, the head gaskets are marked front and they are on correct?? doesn't have belt driven water pump of some sort rotating wrong direction?
Just mentioning some basics hadn't seen mentioned.
electric style gauge readings can be screwy sometimes,have seen sealer on threads of sensor cause bad ground for sending unit and read incorrect or not at all.
Mike Taylor 3601
Old 07-25-2016, 08:35 AM   #3
Todd Gross
Mike Taylor 3601
Hi Mike,
The gaskets are on correctly. No insult taken.
The water pump is a Pro-Form Electric. The owner is going to try swapping a Meziere pump off his other car, as well as removing a medium size restricer from the T-State housing and test.
As for the sensor, we are referring to a 3 wire sensor for the Holley EFI data log. We have tried another sensor with same result to rule that out.
Also have found out that the car had a puke tank for the Radiator and he changed that out to a recovery tank. Once I hear results of testing after these changes I will update post.
Thanks- T Gross
Old 07-27-2016, 09:54 PM   #4
Todd Gross
Update*
Customer tested last night. No problems. Monitored during multiple runs.
Although 3 things were changed, I believe the addition of the recovery tank was the helper here.
It appears that the Siamese cylinders of the Dart block is not as forgiving when it comes to moving air pockets that were introduced after cool off.
