#41 |
Liked 7,909 Times in 1,754 Posts
It was and it should be gone.
#42 |
D-Darts had factory modified (intake openings bored out to accept Holley) standard 273 intakes. AND adapter plates.
#43 |
Liked 49 Times in 22 Posts
I have found the early 64-66 blocks are better, i have a 65 block in my car, with some fill, all good so far, and i am just using the hooker headers for now, until i have Performance Welding build me a set someday.
Steven Barnes Stock 704 N/SA |
#44 |
Liked 346 Times in 126 Posts
#45 | |
It's a single plane cast iron intake with an adapter for the Holley carburetor. |
#46 |
Liked 68 Times in 26 Posts
hi, just curious, I seen marine intake for 318, casting number is2846707. the carb flange is angled quite a bit from level, thanks
#47 |
Liked 53 Times in 38 Posts
The ones I've seen had angled spacers under carb, dad had two 400s with them. First boat had a ford 351 engine, angled spacer under carb.
#48 |
771 is also listed as 66 California.
#49 |
The LD4B Edelbrock intake was approved as a replacement for the 273 due to the fact it was available with a Chrysler part number. The same rationale used on the 440 Chrysler 6-Pack engine with the Edelbrock intake. The 6-Pack intake was available in both aluminum and cast iron.
#50 | |
