Old 04-23-2017, 12:51 AM   #1
Stephen & Horace Johnson
Liked 161 Times in 52 Posts
Default Re: 69 Chevelle AA/SA 10.04 at 125mphat Spring Nats
Originally Posted by larrylomascolo View Post
Austin Williams in seat,Is this a 427-425HP combo to run AA/SA??
Yes.
Stephen Johnson #2162
Horace Johnson #2167
Stephen & Horace Johnson is offline   Reply With Quote
Old 04-23-2017, 09:05 AM   #2
Liked 1,830 Times in 415 Posts
How did an 69 Chevelle 427/425 automatic make AA? The 69 Chevelle 427/425 automatic is a natural B car. We even asked if using aluminum heads to make the HP factor 435 would make it a natural A car with an automatic, and were told "no". The automatic has been a natural B car for as long as I can remember, back to when Harry Vineyard ran one back in the eighties and early nineties.Harry drove the car with an automatic in B/SA, and it was a killer. They put the 4 speed in and Tucker Parrish drove it in A/S, and it was just as wicked. I think Kevin Borgstrom put the 4 speed in his beautiful green Yenko clone just to run AA.
Old 04-23-2017, 09:21 AM   #3
Tom Moock
Liked 10 Times in 6 Posts
Alan, Don`t stick & automatic fit the same class`s? stick 8.36, automatic 8.49.
Tom Moock 5704 STK
Tom Moock is offline   Reply With Quote
Old 04-23-2017, 09:52 AM   #4
Liked 10,714 Times in 2,230 Posts
A= 8.00 lbs - 8.49 lbs per NHRA. A car can move up or down one class from natural class. So the car is a natural A car at 8.49 with the automatic. To fit AA/SA the car with driver would weigh 3355# min. to 3565# max.
Old 04-23-2017, 09:56 AM   #5
Dave Casey
Liked 792 Times in 165 Posts
looks correct to me, by NHRA,s guide it's a natural A car , I did notice that Dwight's site lists the auto as falling at 8.50, and nhra says 8.49. not sure why they are different.
These cars have been run as A cars for ages, Denny Ford and Jim Benjamin both ran them as sticks back in the 70's and 80's , long before we could move a class up or down and I don't think the rating has changed
Dave Casey 1330 STK
Old 04-23-2017, 07:34 PM   #6
M Brand 505B
Liked 31 Times in 10 Posts
The 8.49 was recently brought to NHRA's attention hence the change. I would assume NHRA rounds down even if its 8.499 like they do on class weight ex. 3449 is 3445. The rule book doesn't seem to cover how weights and indexes are rounded though except for adding/taking away HP and that is rounded up ex 2.15 is 3.
Michael Brand II
505B - F/SA
M Brand 505B is offline   Reply With Quote
Old 04-23-2017, 07:50 PM   #7
Adub464Q
Adub464Q's Avatar
Liked 478 Times in 91 Posts
We can't sneak anything past you guys on here!
Yes, I was running a 69 chevelle with a 427/425 combo, with aftermarket heads rated at 435 hp. The car is owned by Will Carrell out of Oklahoma and he's done an awesome job building this combo. Regardless of the head, the factor is still done with the advertised hp (425).
The shipping weight is 3611. When doing the math,
3611/425 = 8.496....hence the dilemma. I did the math and Will brought it to NHRA's attention that it should be a natural A car, similar to what Larry mentioned above. Pat was in agreement that the excel sheet was incorrectly rounding the factor up. He adjusted the excel sheet this week prior to us entering the national event on Thursday. We did not enter the class until the sheetvwas changed online.
This was all done because AA at a minimum of 3430 is much more attractive than C at 4000+ lbs. Not to mention that it is much more safe.
If anyone would like to discuss this, PM me and l will give you my phone number.
Also for the record, the car is really cool and wheelie fun to drive.
Austin Williams
3 SG
464Q STK SC
Adub464Q is offline   Reply With Quote
Old 04-23-2017, 10:08 PM   #8
MR DERBY CITY
Liked 7,939 Times in 1,520 Posts
Nicely played, BRAVO.....
Old 04-23-2017, 11:07 PM   #9
Austin, congratulations to both you and Will, and thank you! Good luck racing that car.
By no means was I complaining, questioning, or saying you did anything wrong, Austin. You got them to move that combination to a natural A combination, finally, and I'm glad you did. Thanks again.
Old 04-23-2017, 11:23 PM   #10
Adub464Q
Adub464Q's Avatar
No problem, just explaining the process we went through for everyone. Like I said, we didn't turn the tech card in until it was fully changed online, even after getting a verbal confirmation.
Also, I will be back in the duster soon enough, we just had an issue come up with that car.
You know you've done something when Jason line looks at the car and says "What combo runs AA in a chevelle?"
Austin Williams
3 SG
464Q STK SC
