Old 05-11-2017, 07:35 PM   #1
SDT1DYI
Liked 455 Times in 147 Posts
Default Re: 68-70 Nova Stocker Pinion Angle
Its at .06 now. Was going to install 2 degree wedges to start but maybe I should install the 4 degrees and see if it likes it to start. Anybody play with a pyrometer readings at the U joints?, checking temps with Pinion angle changes to determine best angle. Thinking is, closer the angle is under a load, the less heat is being generated by the U joint as it rotates.
SDT1DYI is offline   Reply With Quote
Old 05-11-2017, 08:12 PM   #2
GTX JOHN
Liked 2,486 Times in 697 Posts
Just a couple or three degrees in Boulder City works great.
John Irving
741 Stock
741 Super Stock
Old 05-11-2017, 09:21 PM   #3
Todd Bailey
Liked 33 Times in 17 Posts
Call Travis at Calvert racing.
Todd Bailey is offline   Reply With Quote
