#21 | |
What you are referring to is the factory inlet portion of the assembly that connects to the remainder of the fuel injection air cleaner assembly. The fuel injection inlet is not connected to the carburetor, therefore, it does not act like a ram air system. I doubt it has any effect on the performance of the engine since it's not connected directly in any way or form to the carburetor. It's removal will not effect the performance of the car. |
#22 | |
Liked 64 Times in 14 Posts
but if its on that car it is worth something And since its a carb car I assume that should not be on the car I guess that may show an issue with no tech at national events
Mark Callanan 1027 STK |
#23 | |
Liked 314 Times in 177 Posts
#24 |
Liked 319 Times in 68 Posts
That's the secret 1.20 inlet system, the fast guys have them. must be in West Coast rule book.
Lee Valentine 1661 STK |
#25 | |
If it was so effective, why racers with FI remove the whole assembly and use a straight K&N air filter directly on the throttle body? The drop down carburetor base is more effective since it distributes the air more efficiently at the carburetor entry. |
#26 |
Liked 7,891 Times in 1,753 Posts
If it doesn't belong there and it isn't worth anything then why is it there? You're betting with other peoples money.
#27 | |
Guest
Posts: n/a
Depends on the carb setup. Not all gains are about cold air. Just saying. It can change the fuel curve going down the track. If it's run, it could be for a reason.
#28 |
Liked 80 Times in 29 Posts
It certainly doesn't appear to have any business there although it is a very ineffective device, even when utilized with the fuel system for which it was designed.
Using pressure barometers as well as other measuring tools, this vehicle has almost 18,000 CFM of airflow being delivered to the front of the engine at highway speeds. The drop base is a very conventional unit available almost anywhere performance parts are sold. I've tested both the factory fuel injected inlet shown as well as countless bases. The benefit of utilizing the 14" base is not to create an evenly distributed entry profile. The car is unlikely to realize this plastic component exists. However, rules are established and must be complied with. |
#29 | |
I guess this is what happens when someone spends hard earned money with Gulius.
No prep is king |
#30 |
Seriously Todd?!? Come on this is not a max wedge.
No prep is king |
