#1 | |
Liked 77 Times in 15 Posts
Never had an issue with either car, and we have sportsman systems in both stockers. We have always picked up using a magnet in the input shaft using that part, never tried anything else. Always works, if it stops working, it has probably threaded out and lost the required gap to the magnet, and improper gap will also give you really weird graphs. With Input and DS speed and a few simple math channels, you should have everything you need. |
Liked 39 Times in 13 Posts
With out a doubt it is G-Force! Bubba and Paul are Great to deal with. Their stuff is tough as nails.
J. Wayne Totaro 1117 STK |
#3 | |
Liked 10 Times in 6 Posts
Liked 24 Times in 8 Posts
Liberty Gear 5-speed with the Long shifter.
They will get you the trans ratios you need for your combo. |
Liked 225 Times in 136 Posts
Much better service from G-Force QUOTE=Don Anderson;576108]Liberty Gear 5-speed with the Long shifter. They will get you the trans ratios you need for your combo.[/QUOTE] |
Liked 1,954 Times in 491 Posts
Just looked at the G-gorce ratio chart, impressive.
Todd Greene |
Liked 299 Times in 48 Posts
Hey Don - Which Liberty 5-speed trans are you running? Any idea what that trans weighs alone?
Mike,
Aluminum case & tail housing goes about 100 lbs. Magnesium case & tail housing are 8 lbs. lighter. I had Paul @ Liberty Gears help me upgrade an old Doug-Nash 4+1 back in 2008 to Liberty`s face plate system legal for my 1985 M/S NHRA Stock Mustang and up-grade the shift shaft seals in the case. I know for Super Stock racer Terry Johnson who went to Liberty`s 5-speed and picked up .2 in his car and made it more fun to drive again. |
#10 | |
Liked 684 Times in 289 Posts
...4 speed only Last edited by Mike Jones; 11-05-2018 at 03:21 PM. |
