#11 |
Liked 10 Times in 6 Posts
When I was building my 68 Camaro a few years back,I had to buy the entire set up for a stick.I talked with Rob Youngblood and John Calvert,both said without hesitation to run a 101A.Good enough for me.
Matt Welker-what sensor and V-net cable do you run? I had trouble getting a good clutch graph on my racepak sportsman with various combinations of cables and sensors.Went to the picking up the signal off my input,works fine. |
#12 | |
Liked 77 Times in 15 Posts
Never had an issue with either car, and we have sportsman systems in both stockers. We have always picked up using a magnet in the input shaft using that part, never tried anything else. Always works, if it stops working, it has probably threaded out and lost the required gap to the magnet, and improper gap will also give you really weird graphs. With Input and DS speed and a few simple math channels, you should have everything you need. |
#13 |
Liked 39 Times in 13 Posts
With out a doubt it is G-Force! Bubba and Paul are Great to deal with. Their stuff is tough as nails.
J. Wayne Totaro 1117 STK |
#14 | |
Liked 373 Times in 131 Posts
That buying a used/refurbished one is a better choice
Alan Mackin Stock 3777/ SS 3377 P/SA & SS/PA Fox Thunderbird I/PS '95 Mustang GT |
#15 |
G-Force! You will NOT regret it!
Joe Martens AA/Stock 3969 |
#16 | |
#17 |
Liked 25 Times in 9 Posts
Liberty Gear 5-speed with the Long shifter.
They will get you the trans ratios you need for your combo. |
#18 |
Liked 226 Times in 137 Posts
Much better service from G-Force QUOTE=Don Anderson;576108]Liberty Gear 5-speed with the Long shifter. They will get you the trans ratios you need for your combo.[/QUOTE] |
#19 |
Just looked at the G-gorce ratio chart, impressive.
Todd Greene |
#20 |
