Old 01-25-2019, 12:39 PM   #21
Ron Gusack
Ron Gusack's Avatar
Liked 7 Times in 6 Posts
Default Re: Penn vs Valvoline test results..Ed Wright
Originally Posted by Myron Piatek View Post
It's my understanding that multi-viscosity oils get circulated faster on start-up when it's cold, which helps protect sooner and reduce wear. I also read some time ago that multi-viscosity oils make more HP, but I don't recall why. It might be that drag engine oil don't usually reach "normal" operating temperatures, if I understand viscosity numbers correctly. (i.e.: 10w-30 - 10w=cold, 30=hot.
Valvoline says that straight weight oils are usually recommended for smaller and older engines.
5th question down:
https://www.valvoline.com/about-us/f...-viscosity-faq
I'll do one more round with straight 30 and then switch to 10-30 to see if my test results move any.
Ron Gusack is offline   Reply With Quote
