Old 09-11-2019, 01:56 PM   #2
Eman
Liked 133 Times in 76 Posts
Default Re: Line Lock Plumbing?
Pressure is pressure, doesn't matter if you had a T or used the LL body as the T, Once you activate the solenoid you pump the pedal and the LL is a one way check valve.
