Liked 36 Times in 26 Posts
It looks like six of the springs are adjustable on pressure, using a Allen wrench , flip it over and see if it has a aluminum drive plate with a steel insert, or a cast iron drive plate. And a Aluminum flywheel, with a steel insert, would take some energy away from the hit. Could be a good piece, also depends what type of clutch disc composition you are going to use. And it appears to be for high rpm shIfting since there is no counter weight
Banned
Liked 179 Times in 89 Posts
Save yourself a lot of heart ache and do it right the first time, Take the guess work out of it, call Rob at Advance Clutch. You'll be glad that you did!!!
https://www.advancedclutch.com/ |
