Old 10-08-2019, 01:18 PM   #8
nhramnl
Liked 358 Times in 83 Posts
Default Re: dual-jet
Originally Posted by e vassar View Post
Should be able to handle 7- 71/2 lbs of pressure. That might help.
Are you running a air filter? A good K&N type filter which richen it slightly.
Or you can simply take it off and hand it to Dean Oliver . That's what we did. Was very happy with his carb.
The "...hand it to Dean Oliver" advice is the way to go, but I would call him first and discuss the concern and what he thinks can be done to resolve it. Dean is the most honest man I've ever dealt with, and if he thinks he might not be able to eliminate the problem (or he thinks you can eliminate it yourself), he will tell you that. Can't say enough good about Dean.
