Old 01-01-2020, 07:34 PM   #11
Dwight Southerland
Dwight Southerland's Avatar
Liked 780 Times in 194 Posts
Default Re: "Old School" Stocker Cams
Originally Posted by Run to Rund View Post
I heard that the original "cheater" stocker cams came about when Joe Lunati took high lift cams and cut off the top of the lobes to max allowable lift. He then used a belt sander to round off the edges until the engine would reach the desired rpm.
Actually the original cheater cams came about when Bill Jenkins could not get a new OEM camshaft from Chevrolet to pass NHRA's specs. (For the "Monster Mash" 55 Chevy I believe.) He went to General Kinetics with the problem and they ground a cam that would pass. In the process, they also added in some area under the curve and voila!
