Old 02-09-2020, 11:21 PM   #1
Jim Hanig
Liked 99 Times in 49 Posts
Cool 327 300 1965 stocker
Anyone want venture a guess on how much HP it will make. ?
Old 02-10-2020, 03:56 AM   #2
GTX JOHN
Liked 2,493 Times in 700 Posts
Default Re: 327 300 1965 stocker
Needs 425 to 450 HP to be competitive.
John Irving
741 Stock
741 Super Stock
Old 02-10-2020, 10:07 AM   #3
HP HUNTER
Liked 373 Times in 129 Posts
I would guess around 440 STP, but how it carries HP past peak would be very important to me.
Old 02-10-2020, 12:12 PM   #4
Needs about 410 to run a second under in I/SA.
Old 02-10-2020, 01:12 PM   #5
Tom Moock
Liked 10 Times in 6 Posts
Jim get a hold of Tony Hernandez tony 5022 . Tony raced his corvette @ 250, 300, 365 hp. Jim Lewis would know hp.
Tom Moock 5704 STK
Tom Moock is offline   Reply With Quote
Old 02-10-2020, 09:11 PM   #6
HP HUNTER
Ok
So we know a 294 CUIN 283 4 jet can make 373 STP HP. 1.27 HP per inch.
Now looking at the 300 HP 327 combination @ 340 CUIN. Bigger bore, more compression, 1.940 intake valve, more cross section in the intake port.
It makes sense to me this engine should be able to make 1.27 HP per inch if not more. 1.27 X 340 = 432 HP. NHRA 365 HP 327 makes 470 HP.
Old 02-10-2020, 09:32 PM   #7
Originally Posted by HP HUNTER View Post
Ok
So we know a 294 CUIN 283 4 jet can make 380 STP HP. 1.292 HP per inch.
It makes sense to me this engine should be able to make 1.292 HP per inch if not more. 1.292 X 340 = 439.2 HP. NHRA 365 HP 327 makes 470 HP.
Sounds good..if you compare it to the best 283 that ever was.
327 /365 has too much difference to base a comparison off of .
http://www.classracerinfo.com/Engine...MAKE=Chevrolet
I don't know how far under you want to go , Jim, but I'm standing by my observation, using my formula that has been pretty accurate over the years.
Old 02-11-2020, 07:55 PM   #8
Frank Castros
Liked 2,761 Times in 976 Posts
Mark,
Please speak more about your formula.
Old 02-11-2020, 08:11 PM   #9
Jim Hanig
Question Re: 327 300 1965 stocker
Mark we would like too run .050 under in race mode . 6/7 under in go faster.the 327 275 i worker on struggled to make 400. this was with old school, but have not ran a AFB carb. so not sure .
Old 02-11-2020, 09:14 PM   #10
Jim, the trick is getting a cam into those things and max compression. My one and only attempt didn't do so well.
Anyway , the AFB deal should fall between the 4 GC and the Q-jet. We know that much .
Other than that, I'd have to look at one closely, with the newer rules, and I just haven't.
As mentioned , Jim Lewis would know the deal on them. I don't bother people at work, that do this stuff for a living, though. I haven't seen the ol' boy at the races in a while.
