Liked 115 Times in 35 Posts
I have a iron case T10 4 speed I got from a stock elim. racer about 25 years ago. The front bearing support says G Force on it and the trans is crash boxed. Believe 1st gear ratio is 2.90-2.99? Were these gears made by G Force or I think Liberty made parts for these back then. I would like to see if it is viable to use this trans. in a street car project I am working on.
It will need gears, sliders and syncros but cluster gear looks ok. Are these parts available to replace what I have in the same ratios? Maybe better off buying something newer. Thought maybe some guys who ran these back in the day might know. Thanks, Jim |
Liked 317 Times in 108 Posts
once its pro-shifted you can't put synchronizers back.. all that area is machined off to install the pro shift dogs.. to go back you would have to replace 2nd. 3rd and main drive
Yes it is a super T10. 26 spline input and 32 spline output.
With the crash box mods I figured the input/main drive, 2nd, 3rd, and even 1st would be replaced. Also sliders and brass. May not be worth it. Just trying to use what I got. |
It is not face plated if that is what you mean. Looks like every other engagement tooth off and I assume the slider same way. Same as we used to do muncies way back when.
Liked 335 Times in 182 Posts
Even If you can find all the parts (sliders-synchros etc.)you will need to convert the trans back to a NON crash box configuration you will have an awful lot of money invested...Not sure how much of that stuff is still out there. That trans hasn't been built in many years--- Might be easier and cheaper to find something else !!!!
Liked 22 Times in 14 Posts
Jim,
You have a PM. Rick Thomason GTOMayhem |
Liked 804 Times in 168 Posts
The factory 1st gear ratios in Super T10 trans. had 2.64, 2.88 and I believe there was a 3.44. There may have been 1 more. These are the trans that were sold aftermarket, not factory installed. Liberty made a 2.99 set that was very popular and I believe only available proshifted. If you have a trans that is a modified factory unit with every other small lug ground of the gears, you could put all the fully synchronized stuff back in it and it will work even though you are missing every other lug on the gears. You would need sliders, brass rings, the 3 little dogs etc. and possible hubs if they were changed to solid ones. This may not be the best way, but it will get you down the road on a budget.
Dave Casey 1330 STK |
Dave is correct.
You could go without the energizer springs . You would just put the dogs in with heavy grease, as you assemble the synchros . It'll have a lighter feel to the shifts, but people did build them that way.
#10 | |
Interesting idea never thought about putting synchros, etc, back in with every other tooth off the gears. That would work but do not think these are factory gears. Thanks for the info. |
