Old 08-28-2020, 07:59 PM   #1
rboyle
rboyle's Avatar
Liked 586 Times in 162 Posts
Default Re: "Live" from Beech Bend 2020 divisional
Thanks!
Old 08-28-2020, 09:56 PM   #2
Liked 10,822 Times in 2,250 Posts
Well it came a gulley washer this afternoon! They were running top dragster so that is what we start out with in the morning. Supposed to start at 9 I think. Everyone to get another run tomorrow then into eliminations. Looks like we can still have rain again so that schedule may not happen.
More later!
Old 08-29-2020, 09:43 AM   #3
Warren Evans
Warren Evans's Avatar
Liked 1,597 Times in 190 Posts
Warren Evans is offline   Reply With Quote
Old 08-29-2020, 10:18 AM   #4
If there is anyone here that knows anything about air conditioners on motorhomes, could you come by and see us? Brand new and it stopped cooling! Thanks!!
Old 08-29-2020, 10:39 AM   #5
Rod Greene
Liked 242 Times in 81 Posts
Larry did it freeze up? The humidity has iced up the ac on my truck a few times I turn it off let it thaw and then it works fine.
Rod Greene Real men shift for them selves. Slowly working on TA Challenger for D,E/S and a 72 Challenger for SS/K, L as if I don't have enough other projects.
Rod Greene is offline   Reply With Quote
Old 08-29-2020, 11:06 AM   #6
Willyracer
Willyracer's Avatar
Liked 57 Times in 24 Posts
Larry we had the same problem with a new Renagade at
Columbus. Our problem is with the power protection module.
It would switch back to battery inventor source.The generator
Would still be running. The AC will not run on battery source.
Shut down the generator and start back up.
We would have a power fault on the control center also.
We have new protection module to install but haven't done it
Let.
Hope this will give you a temp fix on your problem
David
Willyracer is offline   Reply With Quote
Old 08-29-2020, 11:57 AM   #7
Dan Walcott
Liked 92 Times in 26 Posts
Did the cars in Stock and Super Stock that were " DNQ" get OK'd to compete? or is it as the ladder is , after 1st qualifier?
Dan Walcott is offline   Reply With Quote
Old 08-29-2020, 12:48 PM   #8
jmcarter
jmcarter's Avatar
Liked 3,205 Times in 977 Posts
Someone post the ladder please? No live timing for D3, bummer....but thanks to Warren and Unk (and of course this weekend’s primary sponsor, the Bo Butner auto group).
Jim Carter
2340 Super Stock
2340 SST/2340 Stock
Old 08-29-2020, 01:36 PM   #9
Mike Pearson
Mike Pearson's Avatar
Liked 1,945 Times in 586 Posts
Is it still running or stopped all together. Could be the run capacitor for the compressor gone bad.
Mike Pearson 2485 SS
