Old 02-20-2021, 09:56 PM   #1
Jeff Stout
Liked 706 Times in 283 Posts
Default ? On front spring rates on 3rd gen Camaro
Having a discussion on front spring rates with rear leaf spring and cal tracs.
Guy is complaining about car is sitting low on drivers front. He wants car to look straight sitting and put 1 bbc coil spring on drivers and sbc coil spring on passenger. To me this messes up launch of car. Leave same springs on both sides and give what it needs to go straight and fast 60ft.What are others doing if car is not bent. He swears it's in rear suspension parts. Car is bbc and runs high 10s.
Old 02-21-2021, 09:32 AM   #2
Dragsinger
Liked 99 Times in 60 Posts
Default Re: ? On front spring rates on 3rd gen Camaro
Jeff, it an unusual situation. And it sounds like you are in the middle of a conversation that will be difficult to resolve.IF, the car owner truly wants help, this site is a wealth of information.
Larry Woodfin 471W
Old 02-21-2021, 10:53 AM   #3
Jeff Stout
Thanks Larry for the words of advice. I dont pretend to know it all, I just use my experience of what does not work. These guys build big HP motors and then dont think through suspension needs. Then question why the car spins, rear steers, wont go straight and runs in the 11's with 600HP. My bracket car Monte was built around my Ed Quay built Monte years ago and he had done so many tricks to make the car run so well down the track. I can only offer my advice and they can try it or complain I guess.
Old 02-21-2021, 11:21 AM   #4
Chevy55
Banned
Liked 179 Times in 89 Posts
I'd start by making sure there wasn't any bind in the suspension or preload on the rear and then get the corner weights and go from there.
Chevy55 is offline   Reply With Quote
Old 02-21-2021, 11:55 AM   #5
Jeff Stout
Looks like no binding that we have found. The suspension in back is new and lubed. Front has some basic work and has some travel but that 1 bbc coil spring has no energy for movement. I'm trying to get him to use my scales as I'm pretty sure it's a weight placement problem. Shocks are full loose just to make sure they were not holding car up.
Old 02-22-2021, 06:31 PM   #6
Eman
Liked 133 Times in 76 Posts
I'm confused, you say 3rd gen Camaro and then Caltracs and leafs. 3rd gens use coils in the rear with a torque arm and 2 lwr. arms. Frts. use standard style coils only a lower control arm and struts.
Eman is online now   Reply With Quote
Old 02-22-2021, 06:49 PM   #7
Jeff Stout
Maybe I'm confused. What is a 75 Camaro?
Old 02-22-2021, 07:19 PM   #8
KRatcliff
Liked 534 Times in 143 Posts
2nd generation. 1970 thru 1981.
KRatcliff is offline   Reply With Quote
Old 02-22-2021, 07:26 PM   #9
Jeff Stout
Gotcha. I thought 70/72 was 2cd and 73 up was 3rd
Old 02-23-2021, 02:51 AM   #10
Adger Smith
Liked 880 Times in 311 Posts
Jeff,
I would look at engine placement. Most are not put in correctly and cause corner weights W/driver to be out in left field. Then there is always the chassis being square.
good luck..
Adger Smith (Former SS)
