Old 06-03-2021, 02:54 PM   #1
Jeff Stout
Liked 705 Times in 282 Posts
Default Metric 200 lock up trans?
Can a regular 200 be converted to a lock up design? If not how can you tell from the outside of trans that it is a lock up style.
Old 06-03-2021, 03:54 PM   #2
jmantle
Liked 172 Times in 81 Posts
Default Re: Metric 200 lock up trans?
200 lock up will have an electrical connector on the rh side just above the pan rail and the input shaft has a no splines protrusion beyond the splines with an o-ring.
Jim Mantle V/SA 6632
Jim Mantle U/V/SA 6632
jmantle is offline   Reply With Quote
Old 06-03-2021, 04:15 PM   #3
SDT1DYI
Liked 455 Times in 147 Posts
Are any Lock up TH 200's legal in Stock Eliminator?
Steve Teeter STK/SS. #620
SDT1DYI is offline   Reply With Quote
Old 06-03-2021, 05:28 PM   #4
You could use a lock up case for any year, but a functioning L/U would be legal in '81 or newer cars.
Of course , adding that weight to a SB converter, would be a wash, at best, IMO
Edit..Jim Mantle: That would be the LH side (driver's) behind the shift shft, unless you had it in a clamp fixture in front of the bench ;-)
Old 06-05-2021, 07:57 PM   #5
Bill Bogues
Bill Bogues's Avatar
Liked 169 Times in 53 Posts
Cool Re: Metric 200 lock up trans?
I think some of the fast guys are probably running lock up convertors along with steep gearing and a 7 or 8 inch convertor but you're not going to get them or anyone to talk about it..
Bill Bogues 4696 STK
Bill Bogues is offline   Reply With Quote
Old 06-07-2021, 08:23 PM   #6
jmantle
I stand corrected, had to go out to the shop and look. Often thought of trying a lockup in the Pacer, legal if I run it as a 79.
Old 07-14-2021, 03:53 PM   #7
G Anderson
Liked 4 Times in 3 Posts
The lock up trans if I understand correctly has the tag on the side that is labeled 200C--- also if you look at the input shaft you will see a small straight shaft on the very front appx 5/8" Dia and 1-1/4"long
G Anderson is offline   Reply With Quote
Old 08-11-2021, 10:00 PM   #8
Rob Petrie E395
Liked 216 Times in 77 Posts
Can a race transmission be built out of a 200C that originally had the lock up converter? They are not as hard to find as the non lock up torque converter TH200 units.
Old 08-11-2021, 11:52 PM   #9
SSDiv6
I was informed and shown by a former GM transmission engineer that the TH200, Oldsmobile diesel engine powered cars have a beefier case. He had both a standard gasoline engine case and a diesel powered case next to each other. The diesel case was beefier and thicker and also has the universal bell housing pattern. The diesel case was also heavier.
Old 08-12-2021, 12:24 AM   #10
Yes.
Some guys like the earlier pump design in the non-L/U model, and some like to use as new as possible.. I never saw much difference, and have built plenty of both styles.
