Old 04-06-2008, 02:10 PM   #1
Larry Sullivan
Liked 3 Times in 1 Post
Default Re: Belle Rose S & SS combo
Since we get the index from the timing system, I'm not sure how the CICs were being applied.
Larry Sullivan is offline   Reply With Quote
Old 04-06-2008, 03:45 PM   #2
Bryan Worner
Liked 524 Times in 84 Posts
Thumbs up Re: Belle Rose S & SS combo
It appears that they used 1 second under as the cic hit! If, for example, a driver went 1.35 under his 12.05 index in the first round, and won, his second round index was 11.70!!
That had to be a fun race! I really loved seeing a Comp driver get spanked by a certain Super Stock standout! When a 7 under pass beats a better than 1 second under pass.......OUCH!!
They should have more of these! Maybe Dave Ley was paying attention. I could see a Saturday night index race at his next combo!!
I would have loved a seat at the finish line!
Bryan Worner is offline   Reply With Quote
Old 04-06-2008, 05:21 PM   #3
JRyan
Liked 112 Times in 31 Posts
Bryan,
If that's the case, why does Buckner continue running on a 12.00 Index after running 1.26 under the first round, and then way under again later? Whatever the set-up was, it certainly doesn't appear to be consistent.
Jerry
Old 04-06-2008, 05:41 PM   #4
Bryan Worner
Originally Posted by JRyan View Post
Bryan,
Jerry
Do the numbers. He only went .98 under in the final. His index was not corrected after he went 1.2something under in a previous round.
Old 04-06-2008, 06:52 PM   #5
John Mason
Question Re: Belle Rose S & SS combo
Bryan,
DRC shows his dial (not his index) as 12.00 in the final. He went 10.776 which is shown as -1.224 under, with a .010 light. That's a .157 better package.
What part of the math is wrong?
John Mason 7743 SS
John Mason is offline   Reply With Quote
Old 04-06-2008, 07:49 PM   #6
JRyan
Bryan,
I'm aware of the "numbers". My point is that the methodology for listing the INDEX (dial) on a particular car/driver wasn't very consistent. In some cases, they changed the Index, and in others they didn't. It was rather obvious that guys were winning against much better packages, so adjustments were being made somewhere. Moot point now. Congrats to Slate for his excellent driving.
Jerry
Old 04-07-2008, 08:31 AM   #7
Pat Joffrion
Liked 6 Times in 2 Posts
Guys, the DRC input had to be submitted manually for a download. I haven't seen their thread, but I can tell you that the "dial-in" for the 1st round was a driver's index. I personally wrote their dial-in using their respective class index.
Some used a ton of index to win rounds, while others ran less than 1.00 under to save their index. I used each round's run sheet from the tower to make the following round dial-in changes.
The race was a big hit with the drivers and we will definitely do this again next year, and may do it as an all-run instead of class winners only.
Pat
Pat Joffrion is offline   Reply With Quote
