Old 10-26-2021, 08:40 AM   #11
Mike Pearson
Mike Pearson's Avatar
Liked 1,987 Times in 599 Posts
Default Re: Raising Mineshaft Requirements To .95 Under For Stock
Maybe it would be better to consider a race mineshaft by the weather conditions. That is what it was actually intended for. Low temp, high barometer, low humidity and tail wind. So lets say below 62 degrees. Baro above 30.15 Humidity below 30% and tail wind above 7 mph. In my mind that is mineshaft.
Mike Pearson 2485 SS
Old 10-26-2021, 10:01 AM   #12
J.R. Haddad
Liked 1,471 Times in 308 Posts
Mike, I don't want to come across as argumentative, maybe just comparing
regions. At lots of races that I have attended over the years in the Midwest,
I would consider a barometer of 29.5, temp of 75 or less, humidity of 50%
or less, and no wind as mineshaft capable. I can only dream of the conditions you describe at a National Open. I don't know the answer,
but I'm not sure there is a problem. NHRA makes it tougher, racer's get
more creative, what was "GRAY" area, gets missed for a while, NHRA
figures it out, but then realize 40% of the racers are doing it, so it becomes
O.K., and everybody does it=more cost. I think that is where we lose a
lot of racers. Want racers to run it to the finish line, Reward Them.
J.R.
J.R. Haddad is offline   Reply With Quote
Old 10-26-2021, 10:36 AM   #13
James Perrone
Liked 1,865 Times in 435 Posts
It only effects Division 1
We hit the mineshaft more than any other division
We are Bad azz fast over here. D-1. Or we live in fantasy land
Not for the weak.
james perrone 1290 STK
Old 10-26-2021, 10:37 AM   #14
JeremyDuncan
Liked 355 Times in 80 Posts
So when would these weather conditions apply?
8am? 12pm?
Beginning of Stock qualifying?
Beginning of SS qualifying?
Each pair of cars?
What if the parameters were met at the beginning of a session then you had a 2 hour rain delay in the middle of qualifying would they still apply?
Using weather Data is just too unwieldy!
JeremyDuncan is offline   Reply With Quote
Old 10-26-2021, 11:31 AM   #15
Billy Nees
Liked 7,909 Times in 1,754 Posts
J.R.
>>>>>>>>>>>>>>>>>>>>>>>>>Bingo!<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<
Billy Nees 1188 STK, SS
Old 10-26-2021, 11:35 AM   #16
DG
DG's Avatar
Liked 469 Times in 99 Posts
Instead of penalizing performance, NHRA should incentivize performance.
Cash, plaque and 10 points for #1 qualifier, 5 points for #2 qualifier
10 points for setting record
Qualified field at National Events
Cash and 10 points for winning class
Incentives will be more fun and get quicker results than just establishing a new line in the sand.
DG is offline   Reply With Quote
Old 10-26-2021, 12:00 PM   #17
Billy Nees
Only if, at the same time, they expand tech, do more "tear downs" and tighten up on or close the loop-holes and gray areas.
Old 10-26-2021, 12:49 PM   #18
jmantle
Liked 172 Times in 81 Posts
Exactly the problem, if someone destroys my combo by going 1.50 or more under, I want to know it was legal.
Jim Mantle V/SA 6632
Jim Mantle U/V/SA 6632
jmantle is offline   Reply With Quote
Old 10-26-2021, 01:01 PM   #19
jmantle
My take on what would be considered mineshaft.
Density altitude is less than the actual altitude of the track, as determined by NHRA,
to be determined at the start of each round of qualifying and eliminations for that class.
Old 10-26-2021, 01:57 PM   #20
Mike Pearson
J.R.
You are no argumentative at all. Just threw that out there to see what some thought. Those numbers are some that we see here early and late in the season at D-2 events periodically. We can and do get those numbers at the early points races here in Florida like the orlando race or the baby gators.
