Old 12-25-2021, 02:25 PM   #1
chris ok
chris ok's Avatar
Liked 46 Times in 29 Posts
Default Re: Motor mounts
Is it the frame mounts that move the engine or the engine mounts?
I see moroso offers mounts but look like matching pairs. Same as energy suspension.
chris ok is offline   Reply With Quote
Old 12-25-2021, 07:43 PM   #2
L.Fite
Liked 497 Times in 243 Posts
Frame mounts relocate engine. Going from memory about 3/4 or 1 inch.
It's not much but enough to make a difference in fitting headers.
'67-'68 are different from '69, so the motor mounts are different for '69 also.
Don't know why they changed but the width is different.
Also 302 engine frame mount is shorter also...
So there is that...
L.Fite is offline   Reply With Quote
Old 12-26-2021, 09:16 AM   #3
Dwight Southerland
Dwight Southerland's Avatar
Liked 780 Times in 194 Posts
My '67 car was a 327 originally. When I built it as a 302, no problems with fitting. Later I decided to convert to a big block, so I went to Chevrolet and purchased new 396 frame mounts. I ordered headers from Jack Davis and when I tried to install them, they would not clear the crossmember. Jack said the headers were designed to use small block frame mounts "because everybody does that to move the engine back". So the small block mounts wen back into the car.
There is a difference.
Old 12-26-2021, 10:55 AM   #4
tolaas
What i can see i allready have small Block mounts, thank's for your answers Torbjorn
tolaas is offline   Reply With Quote
Old 12-26-2021, 12:21 PM   #5
L.Fite
My '67 was originally a 350 car, when I got it, previous owner had a big block in it, headers hit steering shaft...
Went to Chevy and bought big block mounts and fixed that...
They lowered the 302 for carb/air cleaner fit.
Other than that, nothing dimensionally different, small block is small block.
(probably useless trivia)
Old 12-26-2021, 10:53 AM   #6
Wayne Scraba
Liked 186 Times in 48 Posts
Smile Re: Motor mounts
This article might help...😀
https://www.onallcylinders.com/2021/...sion-position/
Wayne Scraba is offline   Reply With Quote
