Old 12-27-2021, 08:36 AM   #11
Billy Nees
Liked 7,925 Times in 1,760 Posts
Default Re: Can We Un-ring The Bell
Originally Posted by Dyno View Post
Billy, can you explain why you do not like data loggers? After a pass I like to be able to see what my oil pressure was in the lights, the convertor slippage, what the convertor flashed and a couple of other things. It doesn"t make me a better driver, but it might help make the engine last a little longer.
Ok, I'm quite sure that someone will correct me if I'm wrong (I'm not), but can a stand alone data logger in conjunction with a grid and a digital ignition box NOT be used as a down-track timer (the last I knew, not legal)? If it CAN, then it CAN be used to control timing and fuel (and in some cases throttle control) to give the Racer a desired elapsed time.
Billy Nees 1188 STK, SS
