Old 09-28-2022, 07:53 PM   #1
rod
Liked 20 Times in 15 Posts
Default battery ?
I need a group 24 battery. might consider a boat battery, as they are $50 bucks cheaper. just need a battery for 2 races.
Wally World has a cranking boat battery, with 930 marine amps [really, are amps on the water different?] for $100 or a 750 amp deep cycle for $90. a std. Gp24 is $150!!!!!
thoughts.
Thanks Rod in AZ
rod is offline   Reply With Quote
Old 09-29-2022, 08:52 AM   #2
Rsmith38
Liked 28 Times in 15 Posts
Default Re: battery ?
I have been using a group 26 wally world Value bat with 550 C Amps
Works fine with FI fuel pump elect fan and WP Computers, etc. A 11lb bat didn't work but the 450 - 550 CA works fine. I charge after every run.
Rsmith38 is offline   Reply With Quote
Old 09-29-2022, 10:38 AM   #3
jmcarter
jmcarter's Avatar
Liked 3,205 Times in 977 Posts
Hard to beat Costco for Interstate batteries.
Jim Carter
2340 Super Stock
2340 SST/2340 Stock
Old 09-30-2022, 02:46 PM   #4
Fireofficer74
Liked 47 Times in 36 Posts
Costco, I second that, plus great warranty.
Fireofficer74 is offline   Reply With Quote
Old 09-30-2022, 02:51 PM   #5
GTX JOHN
I use Walmart 26 in my Stocker.
One in the front and one in the back.
John Irving
741 Stock
741 Super Stock
Old 10-01-2022, 12:45 PM   #6
SSDiv6
Liked 1,604 Times in 583 Posts
Walmart.
Great price and warranty and you can find a Walmart anywhere!
Old 10-19-2022, 06:43 PM   #7
e vassar
Liked 271 Times in 107 Posts
I have been a loyal Optima Redtop guy for years.
However I just bought the 2nd one in 5 years for one of our cars.
I cant justify the cost if thats going to be the typical lifespan.
I know there are some cheaper AGM,s out there. Anyone tried the Autozone AGM?
Or is it just best to buy the cheapest battery I can find?
Old 10-19-2022, 09:33 PM   #8
Run to Rund
Liked 54 Times in 27 Posts
I have gotten good service, and fast warranty replacement when needed, from O'Reilly's AGM batteries.
Old 10-19-2022, 10:14 PM   #9
Jim Wahl
Jim Wahl's Avatar
Liked 683 Times in 129 Posts
When I got the Volare' in 2010 it had two Odyssey 1200 AGM's in it. I replaced them in 2021. They are the best bang for your 12V racing buck (not cheap) there is I think. The trick is keep a Deltran trickle charger on them. Jim
Old 10-20-2022, 10:34 AM   #10
curtis reed
Liked 125 Times in 59 Posts
I'm with Jim, the Odyssey batteries are the best I have used. The current one in my car I bought in 2017. About a year after putting it in I left the main power on for 5 days and my dial board and misc. led dash lights ran it down to 6 volts. I followed Odyssey's directions to save a dead battery and it's still going strong.
I do have a Battery Tender on it 24-7 when not racing. Other than that 5 days obviously. LOL Also I run an alternator and never charge at the track. I have made 11-13 passes in one day without charging on numerous occasions at our double points races.
Curtis
curtis reed is offline   Reply With Quote
