Liked 327 Times in 121 Posts
Brake lines are a pleasure with this.
Liked 929 Times in 263 Posts
Liked 251 Times in 125 Posts
I've been using an old Imperial, similar to this one: https://www.ebay.com/itm/18551982762...Cclp%3A2047675
I just learned something this past year. I was having a hard time stopping a new double flare from leaking. After googling, I found out if you don't quite finish the second flare, when you tighten the flare nut, it will "finish" itself. I.E. the flare will finish forming as you tighten it against the seat. Presto! After making several flares, including making a new line when it got too short, using this technique, it sealed on the first try. Maybe this is common info, but I thought I'd mention it. |
