Liked 172 Times in 46 Posts
A little line with a die grinder on the lifter oil hole will allow oil to flow, will not need much.
Dirk Olson 5036 STK |
#2 | |
There are few cheaper one that have the oil band well located. Thank you, |
Liked 126 Times in 61 Posts
Did you call Jesel?
Liked 5 Times in 4 Posts
I have seen a few customers had the shop here mill a groove on each lifter. It doesn't need much, seems like it was only 3 thousands deep. Also a issue with Comp lifters and SBC dart block. If you don't groove them, keep a eye on the amount of oil under your valve covers............
Last answer from Jesel tech! Use bushing from us , and if your are installing bushings you will not need to machine the flat on the lifter.
