Liked 2,765 Times in 978 Posts
Lower the indexes.
Frank, you should build a Neon!
Did you post the Stein collage on the HAMB?
#3 | |
The Neon combination doesn't appeal to me. I like fast cars and there is way too much drama within Stock Eliminator for me these days. Sadly my racing days are over. |
and yet, you HAD to comment about lowering the indexes.
[QUOTE=Billy Nees;677942]and yet, you HAD to comment about lowering the indexes.[/QUOTEf
Billy, Yes, it's my belief that would eliminate the AHFS equation and allow the racers to enjoy their hard work and money spent to go fast. I started racing in the late 1970s, had some modest success and have been a member of this forum since 2001. If you don't like my opinions, I can live with that. Frank |
Liked 37 Times in 8 Posts
NHRA did lower the indexes back in the early 90's, I believe, by 2 or 3 tenths. But many complaints reversed that decision as I recall. I talked to several stock racers this weekend in Pheonix and lowering the indexes was a very popular answer to this whole problem. The slowest car in stock was -35 under the index. That would have left him with a .15 second cushion. As a racer, I always enjoyed watching qualifying. Not anymore, almost every car was running 70 to 90 under. That ruined watching qualifying for me. It's not 1977 when I started in Stock. Even my old home built car will run -50 under the index. Times change, so should the indexes.
Liked 598 Times in 164 Posts
Lowering the indexes across the board does absolutely nothing. It changes the numeric values is all that does. A soft combo is still a soft combo but instead of it being a -1.30+ capable car it becomes a -1.00 second car as number 1 Qualifier at Indy let's say.
That is why NHRA uses the AHFS which is flawed obviously but has it's merits. It's the manipulation of it that makes it ineffective. Lowering the indexes across the board just puts the number at a different value across the same board. It's like cutting a foot off the top of your blanket and sewing it on the bottom and thinking you shortened your blanket. |
#8 | |
Liked 1,112 Times in 304 Posts
Liked 10,930 Times in 2,258 Posts
I would enjoy the reinstatement of the qualifying points with a twist. The twist would be ten qualifying points equals a grade point. It would be great to have the qualifying points included in the points chase. That will make some interesting runs later in the year.
This is about performance Last edited by Larry Hill; 03-27-2023 at 11:10 AM. |
#10 | |
Liked 469 Times in 99 Posts
Agree, there needs to be more incentives to go fast for the AHFS to work. The way it is currently, NHRA has incentivized .70 under runs. Bobby Fazio had a nice list of such incentives. The SRAC should take up consideration of a performance incentive program that if widely supported by currently active racers, should be recommended to NHRA. |
