Liked 205 Times in 93 Posts
any sugesstions on which one? inovative, fast, computeck? basicly for family sbc bracket and SS aplications. tks !!!
Liked 269 Times in 99 Posts
Here's another to consider:
https://www.ngk.com/ntk-90067-afx-ai...io-monitor-kit It does not data log if that is important to you. Have seen these in use on engine dynos they are very accurate and reliable.
Liked 91 Times in 51 Posts
Liked 189 Times in 48 Posts
Daytona Sensors - Part #112002 - WEGO™ III
http://www.daytona-sensors.com/wego-...-displays.html I put one in my dragster - it works great - simple to hook up - you can view it on the display in real time and it also records - and they have free, very easy to use software for it. I put a simple toggle switch in the power wire so I can turn it on and off to control the recording time.
Angelo DiTocco '98 Firebird SS/HA '98 Firebird B/SA |
Liked 230 Times in 106 Posts
One will do the job. I do have a LM-1 for sale and it can be upgraded to 2 if ya gotta have.
tks terry...where would the single sensor gbe installed at?
single sensor location?
Liked 136 Times in 49 Posts
If doing a single I would suggest putting bungs in both headers so you can check both banks to be safe. it should be in the collector. if you have evac tubes or anything it needs to be in front of the evac tube. If running open headers it will not be real accurate at idle.
Liked 133 Times in 76 Posts
How well do sensors hold up to race fuel?
