Old 06-06-2023, 08:47 AM   #1
richie 2
Liked 205 Times in 93 Posts
Default Air/fuel meter
any sugesstions on which one? inovative, fast, computeck? basicly for family sbc bracket and SS aplications. tks !!!
Old 06-06-2023, 09:20 AM   #2
Signman
Liked 269 Times in 99 Posts
Default Re: Air/fuel meter
Here's another to consider:
https://www.ngk.com/ntk-90067-afx-ai...io-monitor-kit
It does not data log if that is important to you.
Have seen these in use on engine dynos they are very accurate and reliable.
Old 06-06-2023, 01:30 PM   #3
cad
cad's Avatar
Liked 93 Times in 52 Posts
Old 06-06-2023, 06:42 PM   #4
richie 2
i believe id need a unit that uses 2 sensors? one for each collector...
Old 06-10-2023, 12:09 PM   #5
Angelo DiTocco
Angelo DiTocco's Avatar
Liked 189 Times in 48 Posts
Daytona Sensors - Part #112002 - WEGO™ III
http://www.daytona-sensors.com/wego-...-displays.html
I put one in my dragster - it works great - simple to hook up - you can view it on the display in real time and it also records - and they have free, very easy to use software for it. I put a simple toggle switch in the power wire so I can turn it on and off to control the recording time.
Angelo DiTocco
'98 Firebird SS/HA
'98 Firebird B/SA
Angelo DiTocco is offline   Reply With Quote
Old 06-11-2023, 06:55 AM   #6
Terry Cain
Terry Cain's Avatar
Liked 232 Times in 108 Posts
One will do the job. I do have a LM-1 for sale and it can be upgraded to 2 if ya gotta have.
Terry Cain ???? STK
tcain19689585@gmail.com
Terry Cain is offline   Reply With Quote
Old 06-11-2023, 07:43 AM   #7
richie 2
tks terry...where would the single sensor gbe installed at?
Old 06-18-2023, 07:42 AM   #8
richie 2
single sensor location?
Old 06-20-2023, 09:23 AM   #9
novassdude
Liked 136 Times in 49 Posts
If doing a single I would suggest putting bungs in both headers so you can check both banks to be safe. it should be in the collector. if you have evac tubes or anything it needs to be in front of the evac tube. If running open headers it will not be real accurate at idle.
novassdude is offline   Reply With Quote
Old 06-21-2023, 10:14 AM   #10
Eman
Liked 133 Times in 76 Posts
How well do sensors hold up to race fuel?
Eman is online now   Reply With Quote
