Old 09-16-2023, 06:56 PM   #11
goinbroke2
Liked 393 Times in 153 Posts
Default Re: U/SA
I've always wanted to build a stocker, no way can I afford it, so I'll buy....I'm a ford guy so I can buy a "CJ for $125,000" or a "351C for $70,000" or once in a while, far, far away (in the states, lol) I'll see a pinto/escort/foxbody. There are your ford choices if you want to run a ford in Stock.
302 2bbl is a way I can build a "known killer combo" and being the first time and putting what I can afford into it, hopefully run the index with it.
If it somehow does a -1.00 locally in U, then I'll run T as I'm not going to take top qual as a newby with a contentious combo.
As far as the rest.....
Yes, if the same issue is true for another combo, it should get the same treatment. Somebody mentioned 318 2bbl, if nobody is building them because they are way too high, drop them to factory and let a bunch of cars get built.
Perhaps if a combo hasn't been built or run for X amount of time, hp should be reverted to stock hp? Kind of like records?
Last edited by goinbroke2; 09-16-2023 at 06:58 PM. Reason: Grammar and spelling ADHD, lol
